160 deg Therostat doesnt fit in stock housing?
Old 01-21-2010, 07:12 PM
SWEET98SS's Avatar
Default 160 deg Therostat doesnt fit in stock housing?
I just bought a 160 deg therostat, it does not fit in the stock water neck housing, any ideas? Its a 1999 Z28.
Old 01-21-2010, 07:38 PM
MIKEY'S 2002 TA's Avatar
Default thermostat
have you had your water pump changed??? i had the same problem. mine was changed and it was replaced with the newer water pump that's on the gto's. bought that thermostat and fit perfect.
Old 01-21-2010, 07:45 PM
SWEET98SS's Avatar
the car had 66k when I bougth it and I never changed it, just got the car 6 months ago. The problem is how the actual thermostat sits on the coolant neck. Its too big for the neck.
Old 01-21-2010, 09:36 PM
teke184's Avatar
ls1 is a specific ls1 thermostat...not a standard sbc stat....
Old 01-22-2010, 06:57 AM
SWEET98SS's Avatar
I got this thermostat
Mr. Gasket Thermostat, 160 Degree (LS1)
Old 01-23-2010, 06:43 PM
Restricted User
Zero4488's Avatar
Like was mentioned early their are two style thermostats...just double check your part numbers...
Old 01-23-2010, 09:57 PM
SWEET98SS's Avatar
I checked, I need the whole coolant neck with the thermostat built in. I just purchased one, thanks for the help If any one is looking for just the thermostat, I have one for sale, pm me.
