Solid mounts need poly trans mount?
Old 01-23-2010, 03:26 AM
XtremeDime's Avatar
Default Solid mounts need poly trans mount?
I have spohn solids on my 00 T/A and from what Im reading, I need a poly trans mount is that correct?
Old 01-23-2010, 03:41 AM
71-Camaro-98's Avatar
Well if you have solid motor mounts a poly trans mt. would be the closest thing to get a similar fit on the trans. With everything else you have I would definitely go poly.
Old 01-23-2010, 03:48 AM
XtremeDime's Avatar
Thanks, Ill remember to pick one up when I replace the clutch!
Old 01-23-2010, 05:02 AM
MUSTANGBRKR02's Avatar
Stock rubber will do also.
Old 01-23-2010, 11:25 AM
I just hate the amount of play yo get in your shifter with a stock rubber mount. Given it is only bad after it wears a bit. I think the poly will hold up better.
Old 01-23-2010, 12:59 PM
LSX Mechanic
Damian's Avatar
Keep in mind, a poly trans mount is going to rattle your teeth out. If that doesn't bother you, go for it.
Old 01-23-2010, 06:40 PM
Restricted User
Zero4488's Avatar
Poly mount would work best IMO. It'll stiffen the drivetrain enough so shifting won't be a problem...
Old 01-24-2010, 11:47 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running the solid mounts with a poly trans mount
