Whistling Noise, Help.
Old 02-07-2010, 02:33 PM
1LE4ME's Avatar
Default Whistling Noise, Help.
I installed a FAST intake last year, high flow fuel rails, new injectors, all that jazz. Anyways, after my first highway drive a whistling noise started. I listened to it for a long time, because it never affected driveability or anything. I figured out that it starts out after the engine has been idling a while, because the pressure has to build up first. After I shut the engine off the whistling noise wanes out to a high pitched whistle, and the Whoosh...It sounds like my engine is letting out a sigh or relief. It sounds like the noise is coming from the lower front of the engine, and is not coming from the intake. Anyone ever heard this noise or what it could be?
Old 02-07-2010, 02:53 PM
eseibel67's Avatar
Is it your AC system decompressing?
Old 02-07-2010, 04:00 PM
vteckiller's Avatar
did you install a turbo along with that new intake?? haha
Old 02-07-2010, 04:31 PM
1LE4ME's Avatar
I thought it was the AC, so I removed the belt to test it. Nope. Not the AC.
Old 02-07-2010, 05:55 PM
IKnowtheFuture's Avatar
someone is playing a trick on you and installed a turbo.. you've been PUNKED..OH SNAP! there are cameras everywhere.. i'll be back in 5 minutes with the release forms.
Old 02-07-2010, 06:53 PM
99huggerorangeZ's Avatar
might just be the resonace noise from the airflow through the intake since there is no insulation underneath the base for the intake,like the stock ls1 intake.
Old 02-07-2010, 09:48 PM
garygnu's Avatar
check you PCV system ,maybe the valve is stuck and you here the crankcase venting pressure .
Old 02-07-2010, 09:50 PM
1LE4ME's Avatar
I thought it might be the PCV Valve. I'll have to check it. Maybe putting new heads on it will solve the problem. Any excuse to get some heads, right?
Old 02-07-2010, 09:55 PM
Frozen WS6's Avatar
I'm thinking intake orings. My truck is doing the exact same thing. It sucked the oring in, which is common on vortecs.
Old 12-03-2010, 09:22 AM
Chevy Guy's Avatar
You ever figure it out? I have a FAST 78 that is doing the same exact thing. I heard that the 78's whistled even with no vacuum leak.
Old 12-03-2010, 08:57 PM
trans_am7935's Avatar
did you change out the bolts to the valley cover or grind them down? this can be the cause of many problems of the fast intake.
Old 12-03-2010, 08:59 PM
BRUTL's Avatar
My air pump whistles when it's running. Of course that's only for a couple mins when first started up, but still, when it shuts off it sounds like an airplane shutting down at the gate.
Old 12-03-2010, 09:06 PM
Chevy Guy's Avatar
Yup, I did. Ive found several posts about the FAST intake whistling because of poor design on the inside of the intake. Apparently it is quite common and the porters like Tony Mamo know how to make the noise go away.
Old 12-06-2010, 06:54 AM
Captain Double Post
BOBS99SS's Avatar
Yeah that sucks all that cash on a fast (even when used) and then you got to fork out even more for port work,tony mamo does great things with the fast intakes it would be worth it
Quick Reply: Whistling Noise, Help.
