How much power will i gain?
Old 02-10-2010, 08:47 PM
photoman9988's Avatar
Default How much power will i gain?
I have a 2000 Trans Am and I was wanting to install an LS6 intake and ported tb. My current mods are as follows:
mti clear airlid, k&n filter, hooker longtube headers, ory w/ elec. cutout, slp dual dual catback.
i have the 853 heads which sucks, but i can't afford good heads right now. about how much power to the motor should i make after adding an ls6 intake and ported tb WITHOUT a tune. i want to wait until i get a cam and heads installed to do a tune.
Old 02-10-2010, 08:49 PM
therealcreeper's Avatar
15-20ish max
really need to search for things like this though lol
Old 02-11-2010, 08:10 AM
teke184's Avatar
more like 7-10 honestly...without a cam it won't be THAT high.
Old 02-11-2010, 08:31 AM
i estimated on the higher side, but i don't think 15 is impossible.
the reason i haven't done an ls6 intake is because i've seen too many people only gain 7 or so hp with it. i don't plan on a cam any time soon so it's really not worth the $ to me.
Old 02-11-2010, 12:04 PM
SOMbitch's Avatar
Yep and all of it 4K to redline....
Old 02-12-2010, 12:45 PM
senicalj4579's Avatar
what do you say guys ....probly like 10-15hp? i noticed a higher pul up top on my 98 with ls6 intake
Old 02-12-2010, 04:09 PM
MonmouthCtyLS7's Avatar
Id say 15-20...I probably saw 7 from just the ported stock TB alone.
Old 02-12-2010, 04:14 PM
1gt2nv's Avatar
Hell, 15-20 isn't to bad. I'm installing a LS6 intake this weekend! Can't wait till spring to drive the car again.
Old 02-12-2010, 08:52 PM
garygnu's Avatar
remove the ribs on the underside of the intake to retain the stock coolant lines.
Old 02-12-2010, 09:26 PM
huh? lol
Old 02-12-2010, 09:40 PM
supersick99z's Avatar
Agreed! That's what I did to mine last week and followed a picture on here of how to do it. Or just buy ls6 coolant lines for $50. And I also recommend buying a new OPS because if you don't know what to feel for or where its at then you're probably going to break it! If you don't need it take it back, but at least you have one if need be.
Old 02-12-2010, 11:24 PM
98z8uup's Avatar
Did you remove all the ribs on the underside of the intake.
Old 02-13-2010, 10:49 AM
1gt2nv's Avatar
You can. There's really no need for all of the fins. Just plug the intake holes with something so chips of plastic don't go into the intake.
Old 02-13-2010, 11:03 AM
Formula98ramair's Avatar
I got some LS6 lines from a guy in Dallas TX for $20 alot less work dont know on how much hp i got but did picked it up oh and a BBK tb too
Old 02-14-2010, 09:54 AM
krissoto's Avatar
The way I see it every ride is different. Some might pick up more, some might pick up less, and there are some cars that are just absolute freaks. I put down 347.6 rwhp. This is what I have lid, filter, intake, p+p t/b, ls6 intake, 85mm mass, LT w/trud duals. I did have it tuned mostly bc its an a4 and wanted every last drop. Either way you go it is a good supporting mod especially if you know your gonna follow up with some other kick *** mods. Good luck
Old 02-14-2010, 06:21 PM
z28bluess's Avatar
15-20 really? i need to do that to my car.
Old 02-14-2010, 06:41 PM
thunderstruck507's Avatar
I'd say more like 10rwhp, especially with no tuning
I think I only gained around 20 rwhp (based on track times) with my ported FAST, but throttle reponse would lead you to believe it was more...feels a lot better
Old 02-14-2010, 07:12 PM
bozzhawg's Avatar
AKA the azz dyno.......
