ls6 intake manifold swap
ok so theres a nice ls6 intake manifold for sale on this site for a good price part number`12573572. i want to put it on my 2000 camaro ss which missed the ls6 intake manifold from factory by 1 year! my last camaro was a 2002 and it seemed faster then my 2000, im guessing bc of the intake. first off is this 300 worth the money for a 10 hp gain and besides grinding down the bottom side of the new manifold so the cooling lines fit is there anything else i have to do for this to bolt up to my car?
It always seems like the 01-02's run harder than the earlier ones. Just must be a combination of the different casting heads and intake. Definitely worth swaping intakes + getting rid of the EGR as the ls6 does not have EGR provisions. You will have a check engine light on though unless you get the EGR tuned out.
I bought HP Tuners and do all the stuff myself. Tuned out EGR/AIR/and the rear O2's since I deleted my cats.
any local shop with hptuners or another ls based program should be able to erase the codes for you... if you plan on doing longtubes and deleting the rear o2s and air injection system then personally i would wait until you get all your bolt-ons done and get the codes deleted when you get the car tuned that way you take care of everything at once and don't spend money on the same thing twice
imo i think '00s are the fastest ones by a negligible amount. if you put a ls6 intake it will be a good amount faster than the rest.
'00s have a bigger cam the the later cars. same heads, same manifolds as the later cars.
not saying this cause i own one lol
