Ticking Sound In Head?
Old 02-15-2010, 11:48 AM
19BLACKBIRD99's Avatar
Default Ticking Sound In Head?
When the car is running it has a ticking sound in the passenger side head, im thinking it is a rocker arm that needs to be tightened, any other suggestions?
I already have the coil packs off because im repainting my valve covers and the coil pack brackets so I figured I would go ahead and try and fix this problem.
Old 02-15-2010, 11:58 AM
Cliff's Avatar
l'm assuming you have stock heads/rockers and springs. If so, check the rockers and make sure the needle bearing have not fallen out. Look for wear on the rockers push them up and down by hand and see if you get any play. If you do the lifters would be the next thing to look at.
Old 02-15-2010, 12:02 PM
I really dont get much play going up in down, more side to side
Old 02-15-2010, 03:27 PM
98TAjwh's Avatar
are you sure there isn't a leak at the exhaust gasket? that will make a ticking sound
Old 02-15-2010, 06:05 PM
MonmouthCtyLS7's Avatar
How does it run...the earlier LS1 seem to be noisy...ive had some valvetrain tap ever since i got my car(owned her a year)...runs like a top....99 bttm end 98 top end.
Old 02-16-2010, 01:13 AM
uphigh07's Avatar
could be a bent pushrod also from an over rev
