tsp true duals ground clearance
Old 02-28-2010, 06:51 AM
purple98haz28's Avatar
Default tsp true duals ground clearance
ok i just got through reading the entire sticky on true duals... i got my td's on the car and it hangs pretty dang low. now i saw that i can flipp the fuel line to gain aboout an in. is there anything else i can do without buying umi's ta. i want to get this tucked up as close to the body as possible from what i hAve read "good ground clearance" with tsp is about 3 to 1/2 in... is that about all i can expect
sounds amazing by the way
Old 02-28-2010, 03:01 PM
well i flipped the fuel lines and tucked it up as far as i could. once i put it on the road i measured 4 in at the back and it was my lowest point. thats pretty good from what i've read on here. i'm about to go measure overall again. others tsp td owners pipe in
Old 03-01-2010, 12:38 PM
sscamaroburn02's Avatar
i'm at stock ride height and my are tucked up pretty nicely. the lowest part being the 2 tips. I'll get some measurements for you hopefully tonight. i don't have any problems and my driveway has a huge drop-off
Old 03-02-2010, 08:41 AM
okay I measured my TD's. I've got 5 inches of clearance at Xpipe area, 4 inches at bullet mufflers and 3 1/2 inches right at 2 tips. It's actually very close to the torque arm right now. I know once I change my suspension and rear end I will have to re-adjust the TD's again for clearance.
hope this helps.
Old 03-02-2010, 08:43 AM
deelong4002's Avatar
Also, i'm assuming you took off the tunnel brace???
I flipped my fuel lines. Its a bitch to get them up there, but it makes a huge difference in tucking them up. I'll try to get a measurement tonight if i can.
Old 03-03-2010, 12:34 PM
thanks for going to get some measurements it sounds like mine is tucked up pretty well as well.
Old 03-03-2010, 12:51 PM
mrx8200's Avatar
I'm looking to go this route with my car as well. So I'm interested in what people find. I'm looking to go down 1.2" with strano springs and konis when I do lower the car, but that's a ways off. I've seen this system installed right and it has pretty good clearance. I mean the stock system hangs pretty low too.
Old 03-04-2010, 01:56 AM
CranMaro99's Avatar
John why don't you just ask me since you'e known my car for a few years?
To the OP: I have TSP true duals, flipped the fuel lines, have an aftermarket UMI T.A. anyways so it's as tucked up as can be and is even more tucked that the stocker Y-pipe. It takes effort but it's awesome.
Old 03-04-2010, 02:23 AM
mrx8200's Avatar
Actually would agree that it's more tucked up than the stock y pipe. And yeah chris I know your car, just wondering if that level of awesome is universal or not
Old 03-04-2010, 11:50 AM
CranMaro99's Avatar
Haha love you man!
Of course that level of awesome is universal, we'll make it so.
Old 03-04-2010, 02:26 PM
mrx8200's Avatar
Kinda came to a realization that it's strange, as a man, wanting your duals tucked up as high as they'll go and hidden away. So much against every natural instinct
Yeah I'm sure if I have Ellis do them they'll be amazing. You think I should do the torque arm at the same time just for the clearance?
Old 03-04-2010, 03:18 PM
CranMaro99's Avatar
I wouldn't. Ellis is for sure a pro. The hangers for the rear of the exhaust are adjustable as we all know so if you end up getting a little bit more space when you do your suspension down the road someday you'll be able to mess with it some more then as well.
Old 03-04-2010, 03:41 PM
GO BABY GO's Avatar
You can also gain some clearance by installing them with your rear end jacked up. It pushes the torque arm up out of the way. My car is lowered and they have great clearance.
Old 03-04-2010, 05:03 PM
TXZ28LS1's Avatar
great to hear guys!! i have a set of BMR springs waiting to go on. i plan on ditchin my magnaflow for a set of sweet thunder duals!!! ground clearance was my only concern.
Old 03-04-2010, 08:05 PM
CranMaro99's Avatar
All you gotta do is spend some time tucking up the true duals and you'll be OK.
At first my duals hung so damn low that I had less ground clearance at stock height than when I lowered my car and tucked them up.
Old 04-20-2010, 03:25 PM
traviSS396's Avatar
Any way we can get some picks of these tsp true duals tucked? and the fuel line as well?
Old 04-28-2010, 12:48 AM
Torque Fiend's Avatar
please let's get some pictures...
Old 04-28-2010, 12:53 AM
brian_rs/ss's Avatar
play with the hangers, maybe have a shop custom weld u a set if u don't have a welder in your back pocket. also might take a grinder to the bottom edge of the turn downs.
Quick Reply: tsp true duals ground clearance
