Wide Band Tune
Old 03-03-2010, 07:55 PM
Ls1Rook's Avatar
Default Wide Band Tune
I was wondering if you need a wide band tune when you are bolt only? I heard you cant adjust A/F the same without a wide band tune.
Thanks.
Old 03-03-2010, 10:05 PM
Lambert695's Avatar
Well a wideband tune will help but it wont be required. Just your car wont be running as well as it should. The computer will compensate a little bit for the bolt ons but people run Lt's and intake etc. with stock tune.
Old 03-03-2010, 10:33 PM
JonCR96Z's Avatar
Thanks.
Depends on which bolt ons you have, but it's not likely to be off enough to make a huge difference.
You really shouldn't mess with your WOT AFR without a wideband.
Old 03-04-2010, 12:05 AM
Ls1Rook's Avatar
Ok so bolt ons is not really necessary to get a wideband.
I'm thinking of adding a pair of ls6 heads (have 853s now), will the computer compensate as well or will the wideband be required?
I want to add a cam later down the road, and i am not really sure if the heads will be worth it on a stock cam.
Old 03-04-2010, 12:52 AM
JonCR96Z's Avatar
If you're still running the stock screen MAF it won't kill you to run the 243s without a tune but it won't be ideal.
Your best bet would be to find someone local with a wideband and have them scan it with the wideband just to check. That way you'll know for sure if you need it or not.
The 243s are easily worth 15-20rwhp on the stock cam. I would run a thinner gasket as well to help get your CR up and lessen your quench height.
Old 03-04-2010, 01:22 AM
Ls1Rook's Avatar
That's some good information thanks guys.
