The truck ignition coil upgrade - Page 3 - LS1TECH
Thread Tools Search this Thread
Old 12-05-2013, 03:01 PM   #41
miami993c297's Avatar
Quote:
Originally Posted by Paul Bell View Post
The truck ignition coil upgrade:
Doing the swap:
The coils are 10457730 (GM part number) (AC Delco part number D585), eight coils needed.
The coil mounting brackets are 10457736 (GM part number), two brackets needed.
The coil harnesses are 12601824 (GM part number) two harnesses needed.
Good luck! Paul Bell
I just received all new parts in AC Delco original packages or GM OEM package:
AC Delco D-585 assembly
AC Delco D-585 Coil
AC Delco D-585 Connectors
AC Delco D-585 Harness 1
AC Delco D-585 Harness 2
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 1
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 2
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 3
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 4
Those parts plus shipping was $593.86.
12-11-2013 D-585 Mounted 1
12-11-2013 D-585 Mounted 2
12-11-2013 Firecore50 custom 1
12-11-2013 Firecore50 custom 2
12-11-2013 Firecore50 custom 3
12-11-2013 Firecore50 custom 4
Christian
Last edited by miami993c297; 12-11-2013 at 06:54 PM. Reason: Info and pictures added.
miami993c297 is offline   Reply With Quote
Old 12-08-2013, 06:14 PM   #42
sjsingle1's Avatar
wow.....how much did all new hardware set you back?
sjsingle1 is online now   Reply With Quote
Old 12-09-2013, 10:30 PM   #43
This is great info. I am planning to use a set on my LS1.
skinsandjrfan is offline   Reply With Quote
Old 12-11-2013, 07:41 PM   #44
That's MISTER MODERATOR
Paul Bell's Avatar
Hey Christian, looks like a nice install.
It's probably best to show pictures in a new post so people know they're new.
You mentioned to me the car wouldn't crank-is it all fixed now and running on the new coils? What was the problem?
Get some better wires. I recommend Granatelli zero Ohm wires.
Paul Bell is offline   Reply With Quote
Old 12-11-2013, 08:07 PM   #45
Thanks for the kind words Paul,
Let me know what section it will benefit the best and I will create a thread.
As I got all components separately, I assembled everything...and inverted the harness.
Cylinder 1 was at 7 and cylinder 2 was at 8...just flipped 180* and cranked immediately!!!
I went for a drive logging as usual...the AFR got leaner everywhere!!!
I decided to launch a WOT on my usual private road with my VBOX...and undeniably power is higher...
A dyno session back to back with LS6 OEM NEW COILS (changing the all hardware is 10 minutes) is programmed and I will report.
Christian
Old 12-11-2013, 08:15 PM   #46
Paul Bell's Avatar
Hey that's great. I was only saying to post it in a new reply, not an existing reply.
Let us know how that dyno session goes.
Most folks (including me) notice better engine response when going to these coils. Power increase is debatable-but in my opinion it adds something.
Old 12-12-2013, 11:06 AM   #47
Christian
Old 12-18-2013, 08:33 PM   #48
Firebirdmuscle's Avatar
Just for future reference for someone, you can use the truck coils on our stock ls1 coil brackets. It will work. Just a FYI if someone wants to save a hair bit of money
Firebirdmuscle is offline   Reply With Quote
Old 12-18-2013, 09:13 PM   #49
Paul Bell's Avatar
Quote:
Incorrect information. See below:
Old 12-19-2013, 06:31 AM   #50
It is not incorrect information, it will fit both brackets. My regular ls1 wires fit as well. I will post pics to verify my information...
Old 12-19-2013, 07:27 AM   #51
great post, I was going to change out my 5.3 coils for f-body coils.
Cross that off the list of things to do. thanks
nofun is offline   Reply With Quote
Old 12-19-2013, 09:44 AM   #52
Paul Bell's Avatar
Alright then, let's see some pics! We're always looking for different ways to get things done.
Old 12-19-2013, 10:54 AM   #53
10-4. I will as promised. Wasn't trying to step on anyone's shoes just putting the information out for others that are considering this. I will have pics up in a few days.
Old 12-22-2013, 11:49 AM   #54
As promised, truck coils on fbody brackets and ls1 regular length wires
Old 12-22-2013, 02:57 PM   #55
sjsingle1's Avatar
neat.....but i would prefer to have 2 bolts holding the coil on
Old 12-22-2013, 04:18 PM   #56
LPE 403's Avatar
You guys are doin it wrong....
Truck coils, yes. Visible....wrong!
LPE 403 is offline   Reply With Quote
Old 12-22-2013, 04:24 PM   #57
Paul Bell's Avatar
Agreed. Using just one bolt will cause the coils to vibrate. This has been discussed elswhere.
And coils under the car? Really? How's that working out in the rain?
Old 12-22-2013, 04:28 PM   #58
LPE 403's Avatar
Lol.....my car in the rain? Blasphemy!!!!
To your "point", it's only for a choice few.....
Old 12-22-2013, 08:19 PM   #59
They are very secure and tightened down good. The coils aren't loose. Never thought of putting them under car but sometimes I drive when the roads are wet so that would be out for me. Cool idea though. I will relocate else where is the future off the valve covers
Old 12-23-2013, 01:44 PM   #60
Paul Bell's Avatar
Yeah......they're still gonna vibrate.
This is simply not the way to do it. Go get the correct brackets-37 bucks each on Amazon.
Related Topics
Thread Thread Starter Forum Replies Last Post
Ls style eng coil packs new 8 coils,brackets, primary wires, plug wires 62n62 Parts Classifieds 67 11-25-2016 04:42 AM
Coil#4,6,7 NO FIRE! Crank Sensor? Reluctor Wheel? Tech Guru's Inside!!! 1QuickT-A PCM Diagnostics & Tuning 23 09-20-2016 04:34 PM
efi24x lt1 harness repin with PICS! merim123 LT1-LT4 Modifications 69 06-21-2012 08:34 PM
Need coil wire harness help ! omc8 Generation III External Engine 15 01-15-2010 08:52 PM
Tags
acdelco, bracket, camaro, coil, coils, d585, ignition, l92, ls1, ls2, output, pn, swapping, truck, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
