Replacing OEM Alternator.. Recommendations?
Last year I was having problems with all my lights flickering and dancing. You can read more in this thread; https://ls1tech.com/forums/stereo-el...me-inside.html
So I think I have come to the conclusion that my alt. is going bad. What should I replace it with?
Right now my radio is all STOCK.. and I have a Red Top Optima..
Thanks
Thanks
105 amps stock. I just did mine and had a rewind shop totally rebuild it for $75 which was half the $$$ of AZ, Advance etc.... I unbolted it and supprted with one hand so I could turn it to get to the plug. There is also a small wire held on by a small bolt on the back IIRC. I have a big front sway bar and dropping it out the bottom once it was loose was a bit of a puzzle but it finally cleared the sway on far driver side. I have an oversize radiator that may have made this a little harder..... All in all 10-15 minutes once the car was in the air. And don't forget to disconnect the battery......
