Need a better power steering cap, oil stick, breather. Blow buy.
It's a boosted engine and the valve cap breater I got from speed inc spurts oil mist out. If I cap it I get blow buy out the oil stick. (Small amounts)
I found the lockable Lokar oil sticks at Jegs, look like good units. Any feedback.
Biggest issue is my power steering cap spits a little fluid out the top anyone know of a better cap or remedy.
Ditch the breather setup and install a catch can. No sense in oiling down your engine bay
Getting locking tubes/caps is a band-aid to your excessive crankcase pressure (bad)
Leaking PS reservoir is generally a sign of too much fluid. Normal seepage is expected overtime but fresh fluid should not run out on a regular basis
