Volant Intake
Off topic, but you didn't happen to buy this car recently from a Craigslist ad near Baltimore, MD, did you?
The car had the same intake on it without the that piece. I have seen several of the new Volant intakes and there is a piece there, but not all of them have it. I swear that this is the same car, it looks identical under the hood.
Not the IAT, look at the last pic and you can see the back of that sensor on the back "wall" on the driver side.
Its for the air pump im sure, which means theres probably a 1" or so rubber hose just hangin out behind the bumper on the driver side somewhere...might have a smaller air filter on it, might not.
also correct me if i'm wrong but i thought 98-00 came with EGR/AIR, 01-02 just had AIR. so seiing that his car has EGR that means it's a 98-00. not a 01-02.
but like i said the PO might have deleted the AIR. ether way OP needs to do some searchin under the hood.
The car is a 98' with a newer engine of unknown origin, doesn't have the perimeter bolt valve covers. It does still have EGR and an air pump, I hear it cycle on when I start the car up.
Would anyone have a picture of where the line comes from the air pump on a stock car?
And yes, I did find the car on craigslist in baltimore.
https://ls1tech.com/forums/new-ls1-o...uestion-2.html
i can tell u that the engine is out of another 98-00 car.
