View Poll Results: Which intake should i get?
Vic Jr.
5
41.67%
FAST 102mm
7
58.33%
Other
0
0%
Voters: 12. You may not vote on this poll
Vic Jr EFI vs FAST 102mm
Old 03-12-2010, 10:51 PM
ford's Avatar
Default Vic Jr EFI vs FAST 102mm
Sadly this thread may not be what a lot of you may think from the title alone.
Essentially I am trying to decide on an intake for my setup. My car has the following mods;
FM13 - 230"/232" .595"/.585" 112LSA
Stage 3 ported 243's
ASP u/d pulley
LS7 clutch
Pacesetter LT's
Tick Master
3" true duals
ARP bolts everywhere
Full suspension
SLP lid
Nitrous Outlet 92mm plate kit - 150 shot
and a ton more, but still a 346 which may make both intake choices not the best.
I realize some of that doesn't have anything to with HP, but i just copy/pasted it on here from another site i am on.
So my choice of intake is between the Vic Jr, with a 92mm TB and elbow(yes i realize the 4150 makes more power)
Sort of like this setup;
http://www.cardomain.com/ride/2977048
http://www.dallasperformance.com/DPC...lane/index.htm
However i would be using it with my nitrous kit and probably add this:
http://www.nitrousoutlet.com/installs/install.asp?id=88
For arguments sake ill assume we all know what the FAST 102mm looks like. Do you think they are both overkill?
I am just so lost on exactly what i want for the car, so im coming to you all for suggestions.
Old 03-12-2010, 11:48 PM
SweetS10V8's Avatar
Just put a 92mm on the FAST 102mm...Your setup is perfect for the FAST.
Old 03-13-2010, 12:03 AM
Detoxx03's Avatar
Can't go wrong with the FAST
Old 03-13-2010, 08:24 AM
CalixEros's Avatar
I would go with the FAST. I have a slightly more modified 346 with the Vic Jr and think I'm switching over to the FAST. The Vic Jr is less expensive, however. If you might be interested in a slightly used Vic Jr with that same elbow let me know.
Old 03-13-2010, 08:35 AM
SweetS10V8's Avatar
Nice....Haha...This is the most honest post Ive probably ever seen.
Your basically saying, "I made this mistake and Im telling you up front, but if you dont want to listen to me...... you can buy my mistake from me!!"
Old 03-14-2010, 10:05 PM
Formulized94's Avatar
x2, I am in the same boat and have a fast ready to set on the car. Never again...
Old 03-14-2010, 11:21 PM
ford's Avatar
It's respectable though, and the offer is still legit and a good buy for someone as they work on a lot of setups, possibly not mine.
Old 03-14-2010, 11:52 PM
StreetSilverado's Avatar
On your setup I'd go with a FAST.
Mines setup for a Vic JR so it works great, I can't complain one bit with mine. My little 370ci put down 497RWHP and 467RWTQ all motor then 663RWHP and 672RWTQ on a 150 hit.
