LT Headers easire to install with trans out?
The m6 on our 2000 TA will be out and I wondered if it would make it easier to put in the LT headers from SLP. They is also an off road y as well. I'm assuming yes. Thanks for any replies.
I installed longtubes headers on my lt1 with the trans out and I thought it made it a lot easier when working from the bottom just because it gave me so much more room to work. It also gave me a better angle to slide the headers in place (from bottom). I would say if your trans in already out, to go for it now.
Trans has nothing to do with it. All depends on which header your using as to how the installation will go.
Get the car in the air high as you safely can, 30" minimum is what you need they go in almost vertical.
Some will require the starter or the steering knuckle be moved.
