two holes in oil pan?
Old 03-20-2010, 09:15 PM
IHEARTLS1's Avatar
Default two holes in oil pan?
what gets hooked to the two holes in the autokraft oil pan on the side above the oil filter. there are two holes on the stock pan too.
Old 03-20-2010, 09:25 PM
Duffster's Avatar
It's an optional connection point for mechanical oil pressure sensor. . . Usually 1 rectangular or ovular hole with 2 bolt holes to sides...
Old 03-22-2010, 02:52 PM
IHEARTLS1's Avatar
where can i get a block off plate for it?
Old 03-22-2010, 04:52 PM
69LT1Bird's Avatar
Actually it is designed for a factory oil cooler. Any dealer can get the block off and gasket.
