Need help w/ meziere water pump install - themostat
Old 03-20-2010, 10:10 PM
Bill00Formula's Avatar
Default Need help w/ meziere water pump install - themostat
I have an older pump that didn't come with a themostat. I bought a small block themostat and it lays flat on the pump, not recessed. The stock themostat housing still has the two progs that held the old themostat so it won't fit over the new themostat.
Does anyone know how it is suppose to work?
Thanks
Old 03-20-2010, 10:43 PM
edwardzracing's Avatar
Not sure if this will help or not...
http://www.ls1howto.com/index.php?article=26
Good luck. Keep us posted.
Old 03-20-2010, 10:57 PM
Thanks, but I had looked at that and they don't address the two posts. That pump is a little different than mine in that on mine the themostat doesn't fit in lower than the surface.
Old 03-20-2010, 11:11 PM
Can you get any pictures? I'm completely lost, sorry man.
Old 03-21-2010, 12:22 PM
Magic Man's Avatar
I think you are trying to put thermostat in the wrong spot.It doesn't go where the stock pump had it but in the upper hole with the stock hole empty.If the tube is in the upper hole it will unscrew and thermo goes in. I had same problem so I hope this helps.
Old 03-21-2010, 12:34 PM
niceguyyy01's Avatar
This is correct. You take out the stock t-stat from the water neck. Then put which ever one you want in the top hose of the pump where the fitting unscrews out.
Old 03-22-2010, 10:53 AM
01'SSLSX's Avatar
im glad i read this before i put my meziere pump on, saved me a headache. lol
Old 03-27-2010, 08:47 PM
Thanks for the help. The pictures confused me. I was trying to put the themostat in the wrong place.
