ET reduction question !
Old 03-25-2010, 01:42 PM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
Default ET reduction question !
on a stock internal car how much ET reduction can i expect from an ls1 intake manifold with ported throttle body to an ls6 intake manifold with a ported TB....thanks
Old 03-25-2010, 02:10 PM
Ls1Rook's Avatar
I'd say about a tenth or 2 after headers, i'm getting mine in a couple of weeks.. and going to the track after.
Old 03-25-2010, 04:43 PM
brian_rs/ss's Avatar
actually you probly wont pick up anything other than a marginal gain. probably not even noticeable. not unless you are running a very consistant set up. ei slicks, stalled a4, full drag susp, etc etc. if you are running a stock suspension, stock tranny, street tire car...the margin for error increases by a lot and any small hp gains that this intake will give you, will be much harder to be realized in your ET.
Old 03-25-2010, 05:50 PM
john shea's Avatar
I've read in other posts that you will trap 2 mph faster but not notice
difference in ET.
Old 03-25-2010, 06:25 PM
AFTICA's Avatar
Gave me exactly a tenth on my cam & bolt on car so something less than that on stock internals.
Old 03-25-2010, 06:44 PM
^u mean your cam+bolt on+stall+gear car? also what tire and suspension are you running?
Old 03-25-2010, 07:30 PM
AFTICA's Avatar
Yes my cammed, bolt-on, stalled, 3.73 geared car. Mostly Stock suspension w/o front sway bar and M/T Drag radials. Just BMR lower control arms and relocation brackets.
Old 03-25-2010, 08:07 PM
Ls1Rook's Avatar
Heres some results, not mine.
https://ls1tech.com/forums/drag-raci...e-results.html
Old 03-25-2010, 10:29 PM
00blacka4's Avatar
i was hoping for a solid tenth....i have headers and everything and drag radials, lid, ported TB all that good stuff so i think a tenth is reasonable guess for gain...
Old 03-27-2010, 03:43 PM
pdbq's Avatar
On my 98 automatic, I'm in the 8.20s-8.50s @ 88-90 mph in the 1/8th mile with the most basic bolt-ons and with stock 3.23 gears. Of course, I just keep spinning my *** off the line.
