How loud will dual magnaflows be?
Hi, currently building a true dual exhaust for my 98 SS. I'll be running hooker headers into dual electric cutouts off the headers, into a ORX pipe and then dual magnaflow turndowns to keep it quiet while cruising. the exhaust will have no cats and the car has stock heads/cam. http://www.summitracing.com/parts/MPE-10416/ are the mufflers. I want my exhaust to be as loud as a stock catted y pipe with a cutout in the I-pipe when the cutouts are closed. Just getting opinions on how loud the exhaust will be, before I drop $130 on mufflers.
Thanks
Thanks
Check the sticky for true duals... Probably get more responses...
https://ls1tech.com/forums/generatio...-pics-too.html
Hope that helps....
Also you can check out ls1sounds.com
Hope that helps....
