LS1 Coolant Idiot Light Temp Trigger
Old 03-26-2010, 08:41 PM
bluemach1's Avatar
Default LS1 Coolant Idiot Light Temp Trigger
Does anyone know the temperature that trips the coolant warning light on a LS1 engine? FWIW, it is from a 2000 Trans Am.
Doing a conversion and need to know this for VDO sender.
Thanks,
Ted
Old 03-27-2010, 02:30 AM
Dskeet6's Avatar
if your tripping the coolant light your car must be running pretty damn hot..... maybe 215-220??? prob more?
Old 03-27-2010, 10:38 AM
bluemach1's Avatar
Thats for sure. The stock 944 sender is set up to have the analog needle gauge and a warning light that trips at around 115, if I recall correctly. That 115 is for the turbo four banger. I know that I am going to need something hotter than that but dont know what stock GM trigger point is. I wonder what is programmed in the ECU stock?
