alternators questions
hey i have read on here somewhere that i can use a diff alternator for my ls1 camaro motor swap. they said i could use a truck one maybe i cant remeber an cant find it on here now. an it said that their cheaper then the advance auto parts ones then the ones that is for a camaro so if u could let me know if this is true are which one it is. thanks jason
Not sure if you considered switching to a Corvette system. It would relocate the alternator entirely. It will reside up high on the passenger side of the motor. You would need a balancer and tensioner from a vette. I helped a friend do an LS swap into an 81 Camaro and the K member was tight with the F Body setup in regards to the alternator. Here is a pic of his motor now.
