Need help with PCV please help
i have a 98 Z28 and I just got my ls6 heads on last night. i have the stock pcv system still on the car and there was a lot of oil inside the intake when it came of so i know i need to do something but just dont know what. Also with the ls6 valve covers the stock pvc does not fit into the DS rear valve cover? Can anyone help? Thanks
You will have to make a few changes, I did when I swapped mine over, The LS6 setup uses a different valley cover with a pvc port also.
To be honest with you the best thing to do is find a way to adapt your hose to fit the valve cover, and to run a catch can, do a search on it and you will find everything you need to know, its basically a little bottle that catches the oil before it can enter the intake.
