BROKEN Header Bolt .... - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 03-31-2010, 02:01 PM   #21
Trevor.j's Avatar
well with the motor out of the car deff more room to work with, esp being on the pass side. and its about the same time to drop/lift the motor than to take heads off in my case. and its prob saving him some money on head gaskets and what not.
Trevor.j is offline   Reply With Quote
Old 03-31-2010, 02:06 PM   #22
cgroh89's Avatar
Quote:
Exactle what I was thinking, No need for a oil change coolant etc.
cgroh89 is offline   Reply With Quote
Old 03-31-2010, 03:14 PM   #23
1969mach1's Avatar
I would not leave it. I had a header bolt brake off aswell on the drivers side. There was about a 1/4" inch of the bolt sticking out. I tried using visegrips with no luck, so i went down to Sears and got a "stud/bolt" remover. You hammer the stud remover onto the stud or broken bolt and wrench it out. It worked great, the broken bolt cam right out. Now if the bolt is broken off in the head, I would drill it out and retap the threads.
But don't go back with 5 bolts.
1969mach1 is offline   Reply With Quote
Old 03-31-2010, 03:55 PM   #24
senicalj4579's Avatar
Quote:
Originally Posted by JOSH13 View Post
I agree with ^^ . Sounds like a LOT more work !!
hey you know what? i was sick of dealing with it,if thats how he wants to do the job and can do it better like that then thats fine with me. Ill be happy when I get the car back. Plus he said its gonna save me $ on materials
senicalj4579 is offline   Reply With Quote
Old 03-31-2010, 03:59 PM   #25
joecar's Avatar
JOSH13,
- which bolt was it (which location)...?
- how did it break (going in or out)...?
joecar is offline   Reply With Quote
Old 03-31-2010, 04:52 PM   #26
Oh I see senicalj4579 .... I hear ya . Joecar it is my second from the front bolt on the driver side .... I broke it putting them on .... Bolt looked a lil sideways when putting it in but I thought maybe it was just me thinking that but headers must have been pushing it to the side .... Even though I have all the others finger tightened in .... I took it out and put it back in a few times and thought it was just me maybe not but ended up snapping as I tightened it down .... Sucks but hopefully I can get it out with out removing the head .... or motor .... lol
JOSH13 is offline   Reply With Quote
Old 03-31-2010, 06:04 PM   #27
TheBlueKnight's Avatar
Same one for me! Second from the front bolt on driver's side I'm gonna angle drill it out one day.
TheBlueKnight is offline   Reply With Quote
Old 03-31-2010, 06:08 PM   #28
When I did my header swap, the back bolt on the drivers side was broke. I took the bolts out of the driverside I had to go back and look at the passenger side because it seemed like I took more out on the passenger side. When I pulled the manifold the rest of the bolt was sticking out, looks like it broke at the head of the bolt. Had the car since 18k miles and it had like 128k on it when I did the header swaps, and no one has ever worked on the car but me and the tranny shop so it had to have been there since atleast when I got it at 18k. I figured if it didnt leak after 110k miles I would be fine. Still no leak, like 1k miles later. I used the gaskets that came with the headers because they were thicker than the stock, just to help some.
VeTTeMaNC486 is offline   Reply With Quote
Old 03-31-2010, 07:20 PM   #29
I was thinking about using some thicker gaskets if I have to leave it in there also
Old 03-31-2010, 08:30 PM   #30
I'm in the process of doing motor mounts and installing Long Tubes on my 00 WS6. The car is 100% original, down to the OEM Plug wires, plugs and clutch ( with 90k on the clock )
The furthest back header bolt on the drivers side was snapped off from the factory. I bought the car from the original owner and he has never had the car in for any repairs.
Anyways, im joining the club.. Lucky me
Bad Notch is offline   Reply With Quote
Old 03-31-2010, 09:08 PM   #31
joecar's Avatar
Some people have made themselves a template out of a thick steel or aluminum plate (i.e. with a few holes to match up with the bolt holes on the head)... thick enough to help guide the drill bit true/straight...
the template is bolted to the nearby by bolt holes, the hole over the broken bolt helps to keep the drill bit true and protects the surrounding head should you slip.
if you have enough room for a right-angle drill.
Old 03-31-2010, 09:25 PM   #32
That's a good idea I didn't think about making a template to protect the head in case the drill slips !
Old 06-12-2016, 09:19 AM   #33
Quote:
Originally Posted by MikeG View Post
Same thing happened to me when I installed my headers about a year and a half ago. It was the bolt closest to the firewall on the drivers side. Tried and tried to get it out, unsuccessfully. Ended up bolting everything up and seeing if it would leak. To this day it still hasn't. I'm not gonna mess with it until I need to pull the heads for another reason. I suppose the super thick flange on the AR headers is a factor.
Quote:
I just found the same thing while I was trying to bolt up my headers last night (same bolt as you guys... WTF makes that one snap so often?!). When I pulled the manifolds off, I figured previous owner must've been doing work on them and was just too lazy to put that bolt back on because it was hard to reach or something, but when I went to try and thread it during header install I realized it was snapped off. Really hoping I can just leave it for the time being and wait until I need to pull the heads for another reason.
samerickson89 is online now   Reply With Quote
Old 03-20-2017, 01:25 PM   #34
Where is the template?
ShovelMan is offline   Reply With Quote
Old 03-20-2017, 03:11 PM   #35
taman86's Avatar
damn, 7 years old thread. blowing the dust off of this one lol. I havnt experienced a broken header bolt on these engines yet but I did on my hemi when I swapped my headers on my truck. tried drilling it, that ended not good but not bad. the bolt hole is f-d. but I put my headers on and swapped stock manifolds back on both without a leak on the hemi. I just tightened the **** out of the bolts around the broken bolt to the point where it felt I was going to rip the threads out of the head. not the best way but saves a head change.
a buddy told me later that if there is even a tiny bit of the bolt sticking out or not too far in the hole, you can weld a nut on the inside to the broken bolt with a mig welded and then loosen the bolt up that way. just an idea.
taman86 is offline   Reply With Quote
Old 03-20-2017, 03:24 PM   #36
joecar's Avatar
Quote:
You just make one, find, cut a plate, or stack/weld a few plates, and drill a few tight holes to match the exhaust pattern on your head (it's easier to do if you have a head on the bench).
Old 03-20-2017, 03:41 PM   #37
I use a left handed tungsten drill bit about 1/2 the diameter of the broken bolt/stud and a cordless right angle drill.
The left handed bit walks the broken stud out about 80% of the time,
if the stud does not come out on its own, I apply heat and then use a can of cold shot circuit tester spray down the hole in the bolt, then use the next size up left hand bit and drill it again, so far haven't had to try anything else.. I have a set of the self drilling collet bolt removers but I figured out that since they usually spin the bolt out before the collet even gets to the bolt that the left handed bits are cheaper Oh and I use a small grinding bur for a dremel to make a small divit in the end of the bolt to get things started.
pdxmotorhead is offline   Reply With Quote
Old 03-21-2017, 06:26 AM   #38
Holy old thread....
I snapped the passenger side rearmost bolt last summer during my install. Really kick myself for it too, because I think it was a dumb error on my part.
Anyway, I discovered Dorman 917-142. It's a kickass clamp that is completely worth the $26 on Amazon. Very beefy design. Been working well for me!
Dorman also has another P/N that wraps around the side of the head - kind of a triangular piece that wraps around the back/front of the head if it's one of the end bolts that snapped. I used the one I listed on the rear side and it fit perfectly, so I see no need for the other design.
Atrus_SS is online now   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Broken header bolt nathan_troy Pontiac Firebird 1967-2002 2 07-02-2015 12:48 PM
header bolts backing out bwilde86 Generation III External Engine 20 11-05-2011 06:14 PM
Loc tite on header bolts? Lots of Speed 1 Generation III External Engine 16 07-23-2009 07:56 AM
Header bolts backing out...Locking header bolts or lock washer? jrob56 Generation III External Engine 20 09-14-2008 11:43 PM
What kind of header bolts are you guys using? tspence45 LT1-LT4 Modifications 23 08-22-2008 06:04 AM
Tags
aluminum, bolt, bolts, break, broke, broken, exhaust, head, header, ls1, ls6, removal, remove, size, stud
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
