New/Existing Diagram for Catch Can (Stock LS1)
Old 03-29-2010, 04:49 PM
CranMaro99's Avatar
Default New/Existing Diagram for Catch Can (Stock LS1)
Hello,
I just ordered a RevXtreme catch can for my car.
Obviously there are many different ways to route the PVC system on LS motors (either due to different stock designs, aka LS1 and LS6 differences, or due to the way an aftermarket catch can system is installed due to application.)
Here is all I am asking for: Is there an already existing diagram for the way I want to install my catch can someone can link me (I searched), or can someone go in MS Paint real quick and make one up? I'm just confused on how to specifically instal the catch can for MY set up.
Here is what I have:
-A 99 Camaro, stock LS1 and PCV system, bolt-ons only.
-I don't want to run a breather as it is a bolt on only car, and someday MIGHT see a cam swap, but the car will never see anything over 400hp.
-The catch can has a BUILT IN PCV. So I don't want to use the stock one that is already used (even though it says I can run both in the directions, but I don't want to after further reading.)
Any body have a routing diagram for my scenario? Much appreciated!
Old 03-29-2010, 05:18 PM
CranMaro99's Avatar
On a totally irrelevant side note, it looks like the drain plug on my brand new RevXtreme catch can is freaking stripped! I just tried to remove/unscrew the drain plug and it's jammed/stuck. God, everything I purchase lately needs to be returned
But anyways, any help would be appreciate.
Old 03-30-2010, 05:19 PM
Gearhead1's Avatar
Hope this helps.
https://ls1tech.com/forums/11059703-post70.html
Old 03-31-2010, 03:54 AM
TORCHD 02 TA's Avatar
This is how I have my PCV catch can set up. Tracy(TLewis405.. something like that) gave me the instructions
Old 04-14-2010, 08:25 PM
CranMaro99's Avatar
Originally Posted by Gearhead1
The instructions via the first diagram (I'm assuming that's the one I use) are the opposite of the "directions" that came with my catch can. This diagram shows the pcv line going to the drivers side head, and in my directions it says that end goes to the intake manifold.
Old 04-14-2010, 10:51 PM
CranMaro99's Avatar
Ok I figured it out, thanks everyone.
One last question though: The connection on the REAR of the passenger valve cover (not the front connection that goes to the throttle body); do I cap that off, or not?
Old 05-10-2010, 03:57 PM
nimrod.sixty9's Avatar
Did you ever cap yours off? I want to make sure of this too...
Old 07-15-2011, 02:56 PM
nastyiroc's Avatar
where do you get a catch can?
Old 07-20-2011, 09:38 AM
Shockwave179's Avatar
RevXtreme or Saikou Michi.
Old 07-20-2011, 07:29 PM
johns777's Avatar
Mike Norris has a catch can as well.
http://www.mikenorrismotorsports.com...atch_Cans.html
Old 07-21-2011, 08:36 AM
85CamaroZ28's Avatar
Ws6 store has them as well.
Old 07-21-2011, 01:25 PM
LilJayV10's Avatar
I'm in for this. I need to see if I have mine hooked up right. It's definitely catching oil but the car still smokes at WOT.
Old 07-24-2011, 11:28 AM
DocEwww's Avatar
They sell the Mike Norris original.
Quick Reply: New/Existing Diagram for Catch Can (Stock LS1)
