Question about my fan settings/ should I get a 160 t-stat
Old 03-30-2010, 10:35 AM
4DSPNKR's Avatar
Default Question about my fan settings/ should I get a 160 t-stat
I got my car tuned last August and the tuner set my fan settings as : Stage1: on@180*, off@ 170* Stage2: on@190*, off@ 180*. He said he did this so he could run more timing. Right now I still have my stock thermostat and my first fan comes on very soon and usually stays running the entire time im driving. The second fan comes on very frequently too. I know a 160* thermostat will fix this but I have been reading and researching and my question is should i just keep everything the way it is now and accept that the fans will be running A LOT, or should I get a 160* t-stat? Also, if I go with the 160, are the fans set correctly and will it be bad/harmful to run the engine this "cool"?
Thanks
Old 03-30-2010, 06:18 PM
4DSPNKR's Avatar
bump for the evening crew!
Old 03-30-2010, 06:44 PM
allngn_c5's Avatar
I have a Meziere EWP re used it on my 402 build with a 160 stat. Similar fan program as you. My fans rarely come on except when I am running for extended high speed runs, or the temps are up. I saw the 170's a few times today sitting in stop and go traffic. Fans never kicked on. Temp fell to 163-165 as soon as we started moving.
Hope this helps, I say get a 160 stat. Fans will only come on to maintain the engine temps when stopped, the stat will keep everything happy while air is moving over the rad. Good luck.
sjsingle1's Avatar
with my 160 T I dont think I have ever seen my fans come on......no changes to the computer either
Old 03-30-2010, 09:22 PM
4DSPNKR's Avatar
ok thanks guys. I plan on putting a 160 in. You dont think the engine could be harmed by running "too cool" though with a 160 and these fan settings though? Just want to be sure.
Old 03-30-2010, 09:29 PM
cals400ex's Avatar
there is no reason to have your fans come on that early when running the stock thermostat. i would almost think about finding a new tuner for setting your fans to come on that low because your stock thermostat doesn't open until much after that. in my opinion, there is no reason to run a 160 in most situations. you do not want it to open to early in cold weather. everyone has their own opinion but i would prefer my coolant temps be around 190 or so.
Old 03-30-2010, 10:22 PM
sjsingle1's Avatar
texas here.......cant be to cool
Old 03-30-2010, 10:27 PM
Duffster's Avatar
160 is too cool for the LS engine...
Old 03-30-2010, 10:30 PM
garygnu's Avatar
dose tool cool of thermostat cause the engine to run too rich?
Old 03-31-2010, 07:33 AM
4DSPNKR's Avatar
dang. so maybe what ill have to do is put like a 185 in and then tune the fan settings up to hopefully find a happy median?
Old 03-31-2010, 07:36 AM
4DSPNKR's Avatar
Why is that?
Old 03-31-2010, 08:23 AM
Duffster's Avatar
because the LS engines run better when hotter...
Old 03-31-2010, 09:18 AM
allngn_c5's Avatar
That certainly is true on a stock ls1. I remember getting scared when the temps were up to 240 !! I only saw one fan on, and then suddenly the second fan came on. Temps dropped fast.
Now my question is, what about highly modified 346's and strokers. Do they run better hotter? If so y does everyone tune them to run cooler?
Old 03-31-2010, 09:55 AM
4DSPNKR's Avatar
I wouldn't consider my LS1 to be highly modified so I think I'm goin to put a 180 stat in it and tune the fans to come on later. This way its a little cooler but still is warm enough for a stock LS1.
Old 03-31-2010, 12:07 PM
DreamState23x's Avatar
I have a 160 and fans set to turn on early like that. My car runs very cool. Yes it does run a little stronger when it heats up, but that is when the block/heads etc. heat up, but my water temp stays nice and cool, relatively speaking. I have a 98 so the first dash on my temp gauge is 160. when driving the needle sits on the 0 of where it says 160.
Old 03-31-2010, 01:33 PM
4DSPNKR's Avatar
thanks for the input fellas. i talked with my tuner today and I've decided to put in a 180* stat in and raise the fan temps to
Fan 1 on/off at: 194°F/185°F
Fan 2 on/off at: 204°F/195°F
hopefully this will solve the problem.
Old 03-31-2010, 11:29 PM
If I was doing it again I would probably go with the 180 as well.
Old 04-02-2010, 04:55 AM
TORCHD 02 TA's Avatar
I have a 160 T-stat in my LS1. I also have a switch panel where I have manual control of my fans and so does the computer.
With that being said
Low fan turns on at 190º and shuts off at 180º
High fan turns on at 220º and shuts off at 210º
I also have a FTRA set up, my car runs a little warmer. I also have a water temp gauge too. if I am crusing my car runs around 185º-190º so my low fan is pretty always on, except in cooler weather.
My High fans come on when either I am in slow moving traffic or shot fast runs (track for instance)
The hottest I've ver seen my car was ~220º
Its annoying that my low fan is ALWAYS on b/c my LED is sooooo god damn bright I need to put a resistir in there to dim it down
Quick Reply: Question about my fan settings/ should I get a 160 t-stat
