Bad stuff in crankcase?
Old 04-05-2010, 10:44 AM
WhiteStallion00's Avatar
Default Bad stuff in crankcase?
I had a knock sensor failure last week, so I went in this weekend to replace both of them. When I tore everything down, the front knock sensor (the one that was throwing the code) was submerged in water and chemicals (engine cleaner, etc) from years of cleaning the engine. It was corroded and just plain nasty.
The rear one, however, had no fluid in it at all but was dark brown (looked burnt). The boot for the rear one had fallen down on it's shaft and was obviously exposing the knock sensor to oil. The fear I have is that with the boot being out of place, all the crap that was in the front sensor found its way into the crankcase via the back sensor (it should have been full, too).
I've been cleaning the engine for years, and there was no sign of any corrosion on the back, i can only assume it's been out of place for a while. I'm concerned about bearing surfaces, etc. Any suggestions on what to do here? I have very little $$ these days and can't afford to tear it down any further (it's also my dialy driver, called in "car sick" today).
I did replace the sensors (both) and sealed around the boots on the top of the valley cover, so this shouldn't happen again.
Old 04-05-2010, 10:49 AM
This is what the front sensor looked like before removal. I didn't get a pic of the rear, I guess. Also, a pic of the camshaft, that doesn't look good
Attached Thumbnails Bad stuff in crankcase?-img00419-20100403-0048.jpg   Bad stuff in crankcase?-img00429-20100403-1123.jpg
Old 04-05-2010, 10:53 AM
02 BLK WS6's Avatar
The cam looks normal to me for being in the engine as long as it has.
Old 04-05-2010, 10:57 AM
Knock sensors, obvious which one is which.
Old 04-05-2010, 10:58 AM
*PHEW*. Thanx, Nathan, that makes me feel a little better
Old 04-05-2010, 11:46 AM
Mart00SS's Avatar
Yea the cam looks fine, cars probably got a bunch of miles on it, looks to be a nice layer of sludge in the oil galley. You should be fine with fixing as you described.
Old 04-05-2010, 11:52 AM
Empatho's Avatar
And that is why I do not clean my engine OK I give, I'm just lazy ...lol
Old 04-05-2010, 11:59 AM
What do we think about the chemicals potentially getting into the crankcase? Seems like degreasers are a bad thing to have get in there.
Motor has 150k miles.
