Chambermouth length question
Old 04-05-2010, 11:07 AM
transam0486's Avatar
Default Chambermouth length question
What's the longest I can go to replace my LM1 resonator with a chambered powerstick (classic chambered in milford, mi makes them)? The overall lengths range from 21" to 31". Thanks.
Old 04-05-2010, 11:50 AM
Blackhawk777's Avatar
If you cut a little bit of your I pipe, the 21 inch stick should fit fine, otherwise if you try to wedge it in there, it'll lower ground clearance and you'll smack it on speed bumps.
Old 04-05-2010, 11:59 AM
really? i was hoping to go a lot longer than that...
Old 04-05-2010, 10:10 PM
Pontiacerator
RevGTO's Avatar
IIRC, they have three sizes. The medium one is the one I used and fits well. Check which one TORCHD O2 TA is using. He's got the right setup.
Old 04-06-2010, 08:57 PM
Yeah but Torchd also has the gmmg catback. He can run whatever length he wanted in that I pipe. The OP is limited somewhat by the fact the loudmouth resonator is a little over 18" long. He'll have to trim the I pipe a bit to make something longer fit or it will drag. Is it the modular loudmouth setup, or the old welded version?
Old 04-07-2010, 04:17 PM
it's the older welded LM1
Old 04-07-2010, 04:41 PM
You'll have to hack it apart to the length you needed to make the chambered muffler fit.
Old 04-07-2010, 08:52 PM
still not sure how long i can go...
Old 04-08-2010, 03:13 PM
Gatsby's Avatar
I just installed a magnaflow bullet that was 21" overall as opposed to the lm that was 18. Not cool. I cut 2" out of the I pipe (anymore and it would affect the i-pipe) and it still hung REALLY low. I hated it and bought a magnaflow catback for $380 shipped on here.
It did sound MUCH better than the slp lm though. Much less rasp but still very loud.
