Fresh LT install and now car won't idle
Old 04-06-2010, 06:46 PM
ChrisUlrich's Avatar
Default Fresh LT install and now car won't idle
I turn the car and it will just die if I touch the gas. So it will idle really rough and if I touch gas, it stalls.
Pacesetter LT's used (no EGR or AIR). I ONLY blocked off the EGR that goes into the top of piece in front of the throttle body. Is there something else I have to block off?
Old 04-06-2010, 07:07 PM
sjsingle1's Avatar
if you removed the AIR........did you plug the vac line??
Old 04-06-2010, 07:10 PM
Ok... it's my cousins car and he's in VA. I don't think he did that because he said the only thing he plugged up was the EGR. I'll have him check that. Thanks
Old 04-07-2010, 05:41 AM
No luck! Said he couldn't locate a loose vacuum line. Although he mentioned didn't plug anything up after the AIR removal. So i'm not sure if he just didn't find it. Any other suggestions in the meantime?
