lq4...lq9.. but what truck is it from.. help
Old 04-07-2010, 10:52 PM
vertiroc's Avatar
Default lq4...lq9.. but what truck is it from.. help
searched but was finding what i needed.. i know on older gm engines, if you search the engine block id and casting number on headsyou can find out what car it came from.. i have a 6.0 not too sure if its lq4 or lq9 (thinking lq4) but i want to know what vehicle it came from, seller doesnt know 100%.
block no.:12551964
heads no.:12556642c 317
sorry if this is the wrong area to post this in.
Old 04-07-2010, 10:57 PM
MASS seller approved
smok'nZ's Avatar
if you pull one of the heads if the pistons are flat tops=LQ9 dished=LQ4
Old 04-08-2010, 04:35 PM
vertiroc's Avatar
do you know of a way to check and see by the number posted what vehicle it came from?
Old 04-08-2010, 04:38 PM
bww3588's Avatar
either way, it came from a truck of some sort. either a 2500-3500 truck or a suburban something like that. if you want to know the exact truck, there should be a laser etched number right above the oil filter somewhere telling the last so many numbers of the VIN.
Old 04-08-2010, 05:37 PM
vertiroc's Avatar
thanks
Old 04-08-2010, 07:00 PM
masterz28's Avatar
http://en.wikipedia.org/wiki/GM_LS_engine
that page helps, if you want to find a certain vehicle with a certain block or heads.
Old 11-21-2016, 12:24 PM
BoostedHulk's Avatar
it should be a 5.3
Old 11-21-2016, 12:30 PM
Restricted User
JoeNova's Avatar
block no.:12551964
I think your block casting number should be 12551364.
No, BoostedHulk, its not a 5.3.
What vehicle it came from is almost completely irrelevant.
Quick Reply: lq4...lq9.. but what truck is it from.. help
