243 heads on LS1 whats needed
What is needed to put 243 heads on LS1?
What gasket is good (plan to spray n20 someday)?
Which headbolts? I have 2004 GTO but I have heard that different sizes that year
Any good valve covers that look good decent price out there?
As far as head gaskets, you can either go with stock GM MLS gaskets or if you're looking to squeeze every pony out of your setup, get a set of Cometics with a .040'' compressed height.
For head bolts, you can get a set of new stock head bolts (do no reuse yours) or what I would do (especially with nitrous in your future), a set of ARP head studs. It may be overkill but that's just the way I like to do things.
Oh and your valve covers will swap over.
Summary:
Gasket: stock GM MLS gaskets
Upgrade: Cometics with a .040'' compressed height (What bore size?)
http://www.thunderracing.com/catalog...mid=28&sid=439
Head bolts: stock head bolts (dont reuse bolts)
Upgrade: ARP Head Studs ARP 12-Point Head Stud Kit , 2004+ Blocks
http://www.texas-speed.com/SHOP/item...d=836&catid=36
