Bought an LS1 Camaro z28, issues?
Ok here is the deal, yesterday at night i finally sold my v6 firebird for 4k with hail damage lol and made a good deal on it. I had my eye on a 01 camaro z28 that looked extremely clean, almost out of the factory and the guy wanted 5k for it, so after negotiating i bought it for 4.5k and everything on the car works perfect until today
I was crusing around the city and i had the A/C full blast, radio almost at full blast, and i was punching it on the freeway to test the car and it ran really smooth, and then suddenly the check gauges came up and the A/C began to blow hot air and the radio started to turn off and on for a few seconds, so i got my first exist of the freeway and on the red light, the car's instrument panel began to flash with the ASR off light abs and air bag and then the SES turn on and then i was like WTF, then i went to the nearest gas station and the car bearly made it and died there,
charged the battery at o'reilly and said it was good but the brand of the battery "EVERSTART" just didnt seem to like my camaro
specs battery when hot 540 amps,when cold 420amps
what you guys think ill post a video of my car
http://www.youtube.com/watch?v=X5hI525NUHA
yeah im fairly new to ls1's I've repaired LT1's and v6's but this is my first time messing with an ls1, really nice motor, i can reach the plugs from the top lol, so if you guys can tell me some tips on how to make it faster without spending an arm an a leg, simple stuff ect.
Also, was wondering what kind of exhaust this car since its not stock, but doesnt sound loud at all, its almost as silent as the stock one?
Aftermarket (NAPA, O'reily, Autozone, Advance) are all similar rebuilt cores. Assuming equal ratings for the Amperage, it's up to you. Choose between a) cheaper cost, or b) longer warranty
i put in a new alternator Ultima is called, the car showed voltage above 13 volts on the voltmeter, but after a few runs and loud revs, the car came back to the red section of the voltmeter and "Check Gauges" appeared again?, i still have my walmart battery in, but they tested it and said it was good? so im not sure what it could be please help lol
ok the (AIR WTF) ..... U NEED TO KNOW ....
1. LS1TECH Z A DATABASE OF 80% OF YOUR CAR INFORMATION !! (OPEN AS MUCH THREADS AS YOU LIKE BUT PLEASE DO YOUR RESEARCH & EVERY1 WILL GLADLY INPUT HELP REQUIRED.
The unknow hose is for the damn air pump (SHOULD BE REMOVED AFTER RACE STYLE HEADERS INSTALL)
if the car has an audio system with amp's ..... it may lead to a dead BATTERY !!
CHECK which gauge is on the red lines .... if its the battery .... then you need a battery re-charge or swap ... BTW CHECK GAUGES INCLUDES the low fuel light ..... post us what's up ..
