O2 sensors
O2 sensors
here it is guy i have a 2000 camaro z/28 with a check engine light on for my oxygen sensors. i recently installed pacesetters long tube header and shortly after that the light came on. the car is tuned and doesnt have the back two sensors. but the cars are for the front there O2 sensor bank 1 sensor 1 switching and bank 2 sensor 1 switching also. i can be just idling at a light and my car would just start to shake. any advice would help.
Once you fix the extensions and the o2's you will be fine. Hope that helps.
ps. I tried to extend my wires myself when i did pacesetters on my 01 TA and had the same problem. Then I bought the extensions and the problem was fixed.
Just some info, I used a bosch 02 sensor, shortly after I got the code that the 02 sensor wasnt active. But I had changed the connector to the square mail connector instead of the flat style connector. Im sure got the wires correct. I triple checked them. But I used butt connectors. You think that would be the problem??
On the ls1's when you try to extend them yourself they dont send a signal quick enough to the pcm. All you have to do is buy the extensions. Look at either casper electronics or another speed shop for the extensions and this will help. As for the bosch o2's the tend to respond slow and usually dont work correctly. The best o2's to use believe it or not are the stock ACDelco ones.
1) Are my front O2's useless now that I've had them in the header bungs but not plugged in anywhere?
2) Do stock O2's really cost $140 a piece?!?!?!
The last piece of my headers install is the O2 sensors. I have my old ones in there right now to prevent an exhaust leak, but they're not electrically connected to anything. I've been reading a bunch of threads and I can't seem to actually find a consensus. It seems like 1/2 of the people who get Corvette Bosch 13111 say they switch slow and still throws codes, the other half have no problems. Same 50/50 rule goes for people who use stock with extensions. Granted the threads i was reading were pretty old, so I don't know if something has changed in the last 2-3 years.
