P1133 p1153
Old 05-12-2010, 03:27 PM
redbird555's Avatar
Default P1133 p1153
Hi guys I know this has been covered before but I cat seem to find the definitive answer I'm looking for. Ive been getting the above codes after I installed my headers and I have even replaced the extensions and old sensors with new corvette densos. Ive come to the conclusion that i just need to have them tuned out however Ive been told that that the code is causing the car to run in open loop and hinder performance. Any truth to this or is there no performance difference.
Old 05-12-2010, 03:51 PM
ws6fitz's Avatar
Im pretty sure that when your car is at full throttle its not even looking at the
o2 readings. But im really not sure........
Old 05-12-2010, 04:23 PM
redbird555's Avatar
thanks I thought that might be the case but I wasnt sure. anyone that can confirm this?
Old 05-13-2010, 03:45 PM
redbird555's Avatar
This might be better suited too the pcm section if a mod would move it would be much appreciated.
Old 05-13-2010, 09:11 PM
Michael02hawk's Avatar
Years ago my tuner simply turned these 2 codes off. All worked well, but last week I decided I wanted the codes on.
To make it work properly, you'll need to de-sensitise the some o2 tables.
I've just updated mine today! I'll run it for a day or 2 to be sure the SES isnt triggered, and will post the info then.
Old 05-13-2010, 09:14 PM
jason2687's Avatar
^^^I'm having the same exact issue. What exactly do you mean by desensitize the O2's????
Old 05-14-2010, 02:29 PM
Okay, the car threw the same 2 codes again. So I dont know what I'm doing in trying to de-sensitize them.
I'm just shutting those 2 codes off.
Old 05-18-2010, 12:51 PM
jason2687's Avatar
I have these same two codes. Should I even bother changing the O2's or should I just get these codes turned off????
The car seems to run fine when the SES light is off after clearing the codes with a predator tuner. After a couple days of clearing them, they will pop up out of no where and I'll get really shitty gas milage.
Old 05-20-2010, 01:09 PM
jason2687's Avatar
^^^^ Bump, for replacement or just tune out the codes if it seems to be running alright??
Old 05-20-2010, 04:39 PM
redbird555's Avatar
just turn them off lol its the easiest way
Old 05-20-2010, 04:44 PM
OUTLAWZ RACING's Avatar
one way to fix it just put the o2 bunges closer to the collector. the o2 dont maintain the heat like the should. I know some people dont like to cut new headers but for the life of me i cant understand why the builders of headers havent put them closer. This codes is 8 years old lol.
Quick Reply: P1133 p1153
