SLP Lid VS. FTP 104mm
Old 05-12-2010, 09:22 PM
StreetSilverado's Avatar
Default SLP Lid VS. FTP 104mm
I've been looking around and haven't seen much of anything on the 104mm Lid. So I got rid of my SLP lid and I'm about to put a 104mm from FTP on it.
I have a SUX2BU style ram-air, going up to the FTP 104mm LID, through 4" piping, into a carb. hat, then through the Accufab 4150. SD tuned.
Any thoughts?
Old 05-12-2010, 11:31 PM
kmracer's Avatar
Any thoughts on gains?
https://ls1tech.com/forums/dynamomet...id-setups.html
or the thread right above this...
Old 05-12-2010, 11:33 PM
kmracer's Avatar
i'd look into a EV carb hat too. boosted guys see big gains with em.
Old 05-12-2010, 11:56 PM
I was looking at getting one over this Spectre. But being I'm not boosted I didn't want to spend that amount of money if it didn't gain anything.
I guess I'll have to give it a try pretty soon anyway.
I was also looking at the CSU but there're so many different people with different opinion/views on how both the EV and CSU worth especially with the split in the EV.
Was kinda curious between the Spectre and the EV for my setup being a non-boosted application
Old 05-13-2010, 12:49 AM
kmracer's Avatar
i've always pondered the same thing.
ANOTHER thing i'd look into, which could result in some damn strong gains (but also could cause clearance issues)
http://www.summitracing.com/parts/WSN-024110
taller would be better, i've never seen one on an ls1, but i know carb guys pick up 20hp on an engine dyno. phenolic is better as it helps keep heat outta the TB. keeps the air colder longer.
Old 05-13-2010, 12:57 AM
Only down side to that is that it's for a 4500 flange. I bet it would work good on a 4500 adapter setup though.
Thats one of the reasons I put the Plate on it in the first place was for height, then I started actually using it . I bet it would help to match the intake to the plate though since there's a lot of "over hang".
Old 05-13-2010, 01:10 AM
kmracer's Avatar
http://www.summitracing.com/search/?...20spacer&dds=1
fail, sorry. canton makes one for 59 bucks? phenloic too.
Old 05-13-2010, 01:17 AM
I might have to give this stuff a try. should probably do one at a time and see if anything gains or loses ET/MPH.
Time to shop for a new carb hat and look into the plates. My 104mm lid won't be here until next week.
Old 05-13-2010, 01:33 AM
kmracer's Avatar
sweet deal. are you SD?
Old 05-13-2010, 01:35 AM
kmracer's Avatar
i'd love to know how it goes too. keep me posted.
Old 05-13-2010, 01:40 AM
Yeah SD tuned.
Here's the setup with the SLP which I think is the bottle neck of the setup as well as the carb. hat, then the extra porting I could do to the intake, and them stock 243 heads I have .
Old 05-13-2010, 02:37 AM
kmracer's Avatar
lookin good. i like that little carbon fibery thinggey down there below the intake..
its definitly got potential though. find those weak spots.
Quick Reply: SLP Lid VS. FTP 104mm
