injectors in truck intake>???
Old 05-14-2010, 07:15 PM
transam150's Avatar
Default injectors in truck intake>???
will ls1 style injectors fit in a truck intake? I do realize the plug is different on the truck harness vs ls1 harness thanks for the help
Old 05-14-2010, 09:55 PM
DSRE's Avatar
No, the truck injectors are shorter, I believe the LS2/LS7 injectors will fit, the trailblazer SS LS2 injectors physically fit but have the gen 4 newer style big plug ins, I have a set of low mile truck injectors if you need some fwiw
Old 05-14-2010, 10:23 PM
transam150's Avatar
hey man I have a set that came with the motor... Do you know what size they are its a 6.0 lq9 2003 came out of a denali, Just wondering because i got a feeling after a cam install its injector duty cyc will be maxed.
Old 05-16-2010, 12:13 AM
DSRE's Avatar
The stock truck injectors should be fine at cam only, iirc they are 28lbs ,you will need a custom tune to maximize the power and drivability fwiw
Quick Reply: injectors in truck intake>???
