help identify oil leak... see PICS
hi everybody
please help me identify these parts leaking... so i can tell my mechanic exactly wut to fix
i took these pics after wiping it down and went for a drive and found that
its dripping or seeping out from the crack between these two parts ???
anybody know what this leak is from? and wut i might need to replace? thanks in advanced y'all!! i appreciate the help
Let the mechanic diagnose the problem that way if he is wrong then you're not paying for the labor. But to answer your question..it is leaking from in between your oil pan and the Transmission bell housing. The leak could be coming from the oil pan gasket, rear main seal or your transmission input shaft, or a combination of the 3 parts.
