Replacement Valve Covers
Old 05-24-2010, 02:16 PM
allbaugh_04's Avatar
Default Replacement Valve Covers
I would like to replace my valve covers with either stock ones or aftermarket ones for an LS1.
I see these on ebay but they look too tall to mount the coil packs on them. I doubt they would fit.
http://cgi.ebay.com/ebaymotors/SBC-C...item19bc8142b4
I see Jegs has some replacement ones too but, they have no holes to mount the coil packs on.
What do you guys usually get?
Old 05-24-2010, 02:56 PM
motoo344's Avatar
I would get the stock ones and get them powdercoated if you want something different. If you just want to replace them I am sure you could find a cheap set in the classifieds. With most of the aftermarket valve covers you would probably have to relocate the coils.
Old 05-24-2010, 03:54 PM
99'CajunFirehawk157's Avatar
I have a used set off of my 99 T/a but I think your 00 PCV hose setup may be different, I have 2 hose connections on the passengers side and one on the drivers, if interested, pm, you can get these powder coated which is exactly what I did and why I have an extra set.
Old 05-24-2010, 04:46 PM
I removed the PVC and added a breather. So that shouldn't be an issue.
I just know that the previous owner didn't change the oil nearly enough.
When i swapped the springs i cleaned them the best I could, but only so much you can do. I think powdercoated black would look good.
Old 05-24-2010, 05:26 PM
bww3588's Avatar
i went with the ones you seen at jegs most likely, the cast aluminum ones with the bowtie and "CHEVROLET" cast into them, i also bought a coil pack relocation kit.
Old 05-24-2010, 05:39 PM
Did you get these?
These arent bad...double the price. Might be better just to paint the stock ones black.
I like these ones cuz i probably won't have to get get a coil relocation kit.
Wait a sec....how do those even bolt in.
Old 05-24-2010, 05:58 PM
bww3588's Avatar
Originally Posted by allbaugh_04
Did you get these?
i got the ones you posted,
the second pic is typical edelbrock being overpriced for stupid ****, thoes arent even valve covers, just covers that go over the existing coils and valvecovers....not to mention they look hideous. if im going to pay 219 plus shipping and tax, ill get actual valvecovers.
Old 05-24-2010, 06:40 PM
Sh0wGoAt's Avatar
Just make sure that on the bottom side of the valve cover (closest to header) where the gasket fits one side of the aluminum extends further than the other. This prevents the valve cover from sliding down as its tightened. A friend of mine just got some tall covers offline that were no name and they didn’t have this. When you tightened them down the cover would slide down on the head and the rockers would rub on the top of the valve cover. Tried it a little loose and it leaked. The stockers are back on now.
Old 05-25-2010, 11:46 AM
Nasty N8's Avatar
All our covers fit without leaking or modification to F-body,GTO, Corvette Trucks and many more and give proper clearance to all aftermarket rocker arms available.
http://www.nastyperformance.com/Valvecovers.html
Old 05-25-2010, 06:43 PM
I actually found that site in a search, thx for posting.
Unfortunately I could never bring myself to spend that much money on something that is just cosmetic.
They look nice though.
Old 05-28-2010, 12:37 PM
1LoC10's Avatar
The Edelbrock covers dont look to bad
Old 05-28-2010, 01:21 PM
w3s1c0a5t's Avatar
They actually look mucho better once installed. Nice looking setup sir.
Old 05-28-2010, 02:53 PM
sscamaroburn02's Avatar
I like the covers!
Old 05-28-2010, 03:54 PM
That's a truck though. IDK if they'd even fit on and f-body.
Old 05-28-2010, 06:43 PM
Sh0wGoAt's Avatar
i like them
Quick Reply: Replacement Valve Covers
