Adjustable Borla exhaust, where to find the adjustable gaskets online?
Old 06-01-2010, 12:19 PM
Not Brian's Avatar
Default Adjustable Borla exhaust, where to find the adjustable gaskets online?
I can't find them on Borla.com and google came up dry after a quick search. Basically, after installing headers/ory my ws6 is extremely loud and raspy. I bought the car with the Borla exhaust/loudest gasket already installed and would like to install one of the more restrictive ones for the street. Anybody know where I could find these?
Old 06-01-2010, 01:12 PM
99WS6Formula's Avatar
Try searching for Borla "plates" not gaskets.
Old 06-01-2010, 01:15 PM
sjsingle1's Avatar
you can get them from borla.........VERY $$$$$
Old 06-02-2010, 07:54 AM
LeftySS's Avatar
An E-cutout might be an option for you as well, if you can't find the plates.
Old 06-02-2010, 09:14 AM
FST SS's Avatar
you could probably make them yourself. I call it a baffle, if you have one just remove it, get some steel plate the same thickness and use your origional as a template. cut the center hole smaller than the one you have. All it does is restrict the pass. side exhaust pushing more thru the muffler to the driver side exhaust.
Old 06-02-2010, 09:53 AM
Engine_HP's Avatar
As said above, you can make ur own plates or a better option would be DMH e-cutout (thats what i have) or look into the https://ls1tech.com/forums/generatio...ack-parts.html (0014239794000)
hope that helps
