TR55 and TR6 missfire!
Old 06-03-2010, 08:51 AM
INIT2WIN's Avatar
Default TR55 and TR6 missfire!
I swaped to MSD 8.5 wires and TR6 plugs on my bolt-on 02 Z28. The TR6 plugs where missfireing from idle to 1500rpms with the car out of gear. I would a multi cylinder missfire code P300. Now i swaped 2 sum TR55s and still get a little missfire at idle but goes away at 1K rpms. Is this a know problem with these plugs? If so what plugs are sum of u runing that dont cause this 2 happen?
Old 06-03-2010, 08:54 AM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
i have never heard of this problem and all the people i have talked to said run the tr55....this is probly the same thing that happened to me to through ur engine bay and make sure all your wires are TIGHT....u have to really push them and they should click twice onto the coil. and then really push them onto the plug i will almost bet this solves ur problem.
Old 06-03-2010, 11:42 AM
Johnnystock's Avatar
Originally Posted by 00blacka4
i have never heard of this problem and all the people i have talked to said run the tr55....this is probly the same thing that happened to me to through ur engine bay and make sure all your wires are tight....u have to really push them and they should click twice onto the coil. And then really push them onto the plug i will almost bet this solves ur problem.
+1...
Old 06-03-2010, 01:52 PM
INIT2WIN's Avatar
Thanks i'll double check myself tonight.
