o2 sensor I.D.
Old 06-06-2010, 07:45 PM
idunno's Avatar
Default o2 sensor I.D.
What is the difference between the pre-cat o2 sensor an the post? The only thing I can see is the length of the wires.
Old 06-07-2010, 06:47 PM
JaYZeig's Avatar
pre..is before the cat...
post is after
Old 06-07-2010, 08:08 PM
idunno's Avatar
You learn that in school?
Now does any body know if there is a difference between the two besides the length in wire?
Old 06-07-2010, 08:19 PM
99345hp's Avatar
Yes, the pre-cat O2 is heated, the post-cat isn't heated.
Old 06-08-2010, 02:36 AM
joecar's Avatar
They're both heated (see pins C and D in HO2S connectors in attached wire diagram)...
On F-body, 3 of the sensors are the same; the 4th one has a different length sub-harness but is otherwise the same.
On Y-body, the connectors might be different (I'm not sure).
Old 06-08-2010, 07:36 PM
99345hp's Avatar
oh, i learned something today. Didn't know the post cats were heated.
Old 06-08-2010, 07:41 PM
idunno's Avatar
I knew I could count on you guys. Thanks a bunch!
