will the Lingenfelter oil cooler adapter fit on 00 fbody
Old 06-07-2010, 10:20 AM
twoolley08's Avatar
Exclamation will the Lingenfelter oil cooler adapter fit on 00 fbody
I've done some searching on here havent found much info. Has anyone installed the Lingenfelter oil cooler adapter on an f body with long tube headers and had any clearance issues at all? I have a 2000 t/a with the hooker super comp lt's. The unit itself is about 1'' thick. Anyone ever install this? have any clearance issue or line routing issue?
Old 06-08-2010, 02:41 PM
twoolley08's Avatar
no one has used this i take it.....
Old 06-08-2010, 02:44 PM
2000Hawk's Avatar
I believe it should work, you would just need the right fittings so you can run the lines easily. You should check in the Road Racing section, or maybe FRRAX.com.
-Joel
Quick Reply: will the Lingenfelter oil cooler adapter fit on 00 fbody
