NW 90 or 102 for my setup ?
Old 06-14-2010, 12:59 PM
RedHottG2's Avatar
Default NW 90 or 102 for my setup ?
Doing a H/C/I setup on my 346 and need to know what TB to get. Engine is still a 346 but will have Advanced Induction 243's and a custom grind cam from them also. FAST 102 and the truck MAF along with Racetronics fuel system. Basically all bolton's along with what's in my sig. From what I understand from Phillip at AI this is going to be a pretty extensive 243 head job and the cam is going to be pretty aggressive (not my dd) although my pistons are not fly cut and it is a stock bottom end 346 and he is aware of this. I just want to make sure I buy the right TB and wanted to ask.
Old 06-14-2010, 01:08 PM
RedHottG2's Avatar
Forgot to mention I'll be using the Fast Toys 98mm lid and the Chris1313 non a/c ram air also if that matters any..
Old 06-14-2010, 01:12 PM
MASS seller approved
smok'nZ's Avatar
i would buy a nw 102 or ptm 102 and be done with it, i ran a 90mm on my 102 at first i didnt not feel comfortable with it on there its so small it didnt even touch the bottom of the tb gasket
Old 06-14-2010, 01:22 PM
RedHottG2's Avatar
Yeah I was thinking the 102 might be the way to go. I know the motor will only pull in as much air as it can so I don't think using the 102 would be to big of an issue.
