Quick TB Bypass question
I did the TB bypass the other day and it was easy except now the coolant line is VERY close (tight, there is almost no slack in the line) to the pulley that is right under the throttle body. ANybody else have this problem or a solution? Might have to just buy some coolant hose and make it longer i guess
Mine is like that also, you could just get some longer hose if you wanted. The only problem I could see with it is if you break a motor mount it would bust it apart (not to likely though). Mine clears everything so I'm just leaving it alone.
