Where to buy cheapest 160 thermostat?
Old 06-17-2010, 02:02 AM
00FirebirdaREV's Avatar
Default Where to buy cheapest 160 thermostat?
As stated I am looking for the cheapest place to pick up a 160 t-stat for a ls1?so far speed Inc has the lowest price at 45$ anyone have info on something cheaper? Thanks for any help given.
Old 06-17-2010, 02:51 AM
JJsQwuik's Avatar
Autozone has them for $29. They're the motorad brand. The same brand slp and hypertech use. Check it out.
Old 06-17-2010, 03:31 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Then don't get a low temp stat. Get a fan switch or have it tuned to have the fans kick off at a certain time. You will lose efficiency if you cut down the operating temperature too much. Most engines today are designed to operate within a "normal" temperature range of about 195 to 220 degrees F. A relatively constant operating temperature is absolutely essential for proper emissions control, good fuel economy, and performance.
Old 06-17-2010, 05:57 PM
02TransAm/Batmobile's Avatar
Have it tuned to come in when, would you suggest?
Old 06-24-2010, 03:18 AM
The tune was my second thought but I'm afraid of the fans being overworked! If I do change the fan setting is around 175 180 a reasonable temp to turn on? My car just runs at 205 or so when prior to my pump change it ran at 190 195?
Old 06-24-2010, 04:55 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It's a dummy gauge in the cluster. Do you have a plumbed mechanical temp gauge to get 205°?
Quick Reply: Where to buy cheapest 160 thermostat?
