Tsp ory
Tsp ory
I've done a bit of research, but I can't find any info on whether or not TSP is currently using a merge-type collector on their ORY's or if they are just one pipe slammed into another pipe - as pictured on their site. I was looking at getting the pacesetter header and TSP ORY combo at the recommendation of someone on this site.
The catted Y has a merge on it, but I cannot afford it and would like to get away from cats.
Thanks
Thanks
I've heard that the fitment is a little better on the ORY's that do use the merge pipe, although I'm sure my 100,000 mile stock motor mounts will test that to the limit
Both the catted and ORY's have the new merge on them. You can do a seach in this section and there are a couple threads w/ pictures of the redesigned y-pipes in them. I don't believe the site has the new merge pictured on them. We have been working on the new site so this one doesn't get the details updated as much as it should.
Thanks!
Jon
Thanks!
Jon
Mine is pretty low. I would say 3.5" max clearance at the lowest point. I'm on DMS springs, around 1.5" drop. I am careful about where I drive and I still scrape on random things every now and then, but its tolerable.
