How to remove steering knuckle to get headers in?
Old 07-08-2010, 03:28 AM
Restricted User
z99ls1's Avatar
Default How to remove steering knuckle to get headers in?
Do I just take the 11mm bolt out at the top of the steering knuckle? OR is there another bolt at the bottom of the knuckle I need to remove ?
Old 07-08-2010, 03:52 AM
Arc00TA's Avatar
Take both 11mm bolts out and pull it off. There is one at the bottom as well. You will need to do both otherwise you will not be able to get the top knuckle off of the steering column. The part where it fits together is too long to just pull it off from one side.
Old 07-08-2010, 07:29 AM
99LSS1's Avatar
Make sure you have the steering wheel straight and locked!!!!
Old 07-08-2010, 10:06 AM
TooLateVTEC's Avatar
I dont remember taking off 1 bolts, I just remember taking one off and pulling the knuckle off the rack.
Yes the wheel needs to be straight, but the knuckle will only go back on 1 way.
Old 07-08-2010, 10:37 AM
2000***camaro***ss's Avatar
yeah just unbolt both and wiggle it a little bit and it should come free. for me, it helped to turn the wheels slightly
Old 07-08-2010, 11:39 AM
99SSJarhead's Avatar
top bolt you want the wheel straight and a 12" long extension and a 11mm deep socket to reach (or I did anyways).
Bottom you want to turn the wheel slightly to the driver side and use a 6" long extension with your deep well 11mm, or even a standard well. Then just wiggle it about. You may have to tap it a bit at the firewall side if it hasn't been removed in a long time. PB blaster can help with this.
Old 07-08-2010, 11:46 AM
Bad Blu Formula's Avatar
What kind of headers are you installing? Are you coming in from the bottom?
Old 07-08-2010, 12:25 PM
Restricted User
z99ls1's Avatar
Pacesetters. I got the steering knuckle off real easy and went under the car and the header slid right in. Now I just gotta go back out there and bolt them up
Old 07-08-2010, 12:27 PM
Restricted User
z99ls1's Avatar
hopefullly the passenger side is that easy to
Quick Reply: How to remove steering knuckle to get headers in?
