FAST 102mm too big?
Old 07-13-2010, 09:22 AM
BlackBirds's Avatar
Default FAST 102mm too big?
Is there a such thing as too big of an intake manifold? I've got an '02 Trans Am with full bolt ons and a TR224 cam and I was wondering if the 102mm Fast intake and TB are "too big" for a stock displacement LS1, or if there's no such thing as too big when it comes to intake air-flow.
Thanks
Old 07-13-2010, 09:30 AM
AznMuscle's Avatar
Too big, no. Not efficent for your money spent, yes. The intake can only give as much air as the heads can bring in. Its all in the set up also though. From many of the people running the 224/224 I have seen around here, the ls6 is fine. For my big *** cam I want the 102 though, since past 6400 the ls6 starts dropping off.
Old 07-13-2010, 09:35 AM
MonmouthCtyLS7's Avatar
What he said
Old 07-13-2010, 10:07 AM
BlackBirds's Avatar
yeah that makes complete sense for a car with stock heads, however aftermarket heads are in the near future.
I've got another question now, do the stock heads restrict flow more than the LS6 intake, or the other way around? For a FAST intake and TB it'll cost about the same as heads, so which is a better to do first.
Old 07-13-2010, 10:21 AM
Darkman's Avatar
LS6 (243) heads and an LS6 intake manifold are pretty closely matched at full lift (0.550 -0.600) flow rates. But aftermarket heads improve flow at the lower lift levels, which the LS6 manifold can already handle. Logic suggests to change heads first for immediate power.
Old 07-13-2010, 10:29 AM
BlackBirds's Avatar
ok great, makes perfect sense. thanks for the input guys, you've been a lot of help.
Old 07-13-2010, 05:57 PM
AznMuscle's Avatar
For your set up, I would also agree heads first, then fast intake later. I am running a 242/248 111 lsa, spinning 7k+, so for me, (honestly both would be more than ideal), the Fast would be a nice jump for me. I also want to do a lot of work to my heads to gain full advantage of my cam and FAST set up, so...more money and time invested.
Old 07-13-2010, 06:44 PM
Musthaveboost's Avatar
102 mm seems huge. Wonr their be a power loss down low over say a 92 mm??
Old 07-13-2010, 07:32 PM
airforcemanss's Avatar
go with a 90/92 tb and a 102 intake. the smaller tb will be easier to tune and there will be no gains if you go to a 102 unless your doing a stroker down the road (4xxci)
Old 07-14-2010, 07:12 AM
SweetS10V8's Avatar
No, The runner design creates its velocity and is what dictates too big, too small, just right. The throttle body opening is just an air bleed to the plenum.
Old 07-14-2010, 09:38 AM
Will their be a HP/TQ loss in the lower RPM's? Thats the primary thing im worried about.
Old 07-14-2010, 02:18 PM
BlackBirds's Avatar
That's what I was originally concerned about as well. Anyone with an answer?
Old 07-14-2010, 02:38 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
NO.....the size of the TB opening is a mute point. Its more advertising than anything else. The runner shape and length and plenum volume are the three biigest factors when it comes to manifold design.
Not to mention we arent discussing applications dealing with carbs where BIG can mean poor airspeed and improper fuel atomization in regards to a discussion dealing with manifolds. A TB is basically an adjustable airblade....thats really all it is.....a carb on the other hand is altogether different as it meters fuel and therefore being properly sized to the application is a much more important scenario.
Hitting on the OP's concerns.....always go heads first than a better intake manifold. Without a really good head a higher flowing intake wont really shine.....for that to happen the stock intake must become a restriction as it certainly does when you place an efficient set of deep breathing heads underneath it.
You would see a little gain in power swapping the intake first but your better off getting heads first and/or doing them at the same time money permitting.
-Tony
Old 07-14-2010, 03:36 PM
AznMuscle's Avatar
And the master himself has spoken...
Quick Reply: FAST 102mm too big?
