241/243 casting ?
You say they can do the work on a set of heads for 1k, does that include the heads? If not I'd agree with thunderstruck, you can get some 241 or 243 heads for a little under or a little over that will flow better from some of our sponsors without the need for a core.
It'd also be about a bit cheaper if you shop around for the 243 heads and then have them do the work.
$1k for labor is steep for those flow numbers when ls1 experts are doing it for about the same or less
A certain place in dallas area will port, mill, valve job, install new dual springs with titanium locks/retainers, ect to your cores for $800. Flow is rated 295 intake 210 exhaust.
Not good Idea..... get TSP heads their prc ls6 flow I think At 315 cfm or around that and their new just for a bit over a thousand if you buy 243 for cheap just take them to get ported for about 300 they do it over here. My brother bought some 243 for 400 shipped and including pay pal fees with valves and everything..
