TPS wire colors?
TPS wire colors?
I am re-routing some of my wiring in my engine bay. I screwed up and need your help. It turns out that there are two identical connectors in the same wire loom that are the exact same length and I can't figure out which goes to the TPS. Any help with the colors of the three wires that go to the TPS would be greatly appreciated. The car is a 98 Trans Am, It should be the same as other years but who knows...
Since you have a '98 might be different from mine. Maybe this will help, has a circuit diagram. www.gearchatter.com/viewtopic8674.php
