true dual over the axle measurements/angles
Old 07-23-2010, 06:55 PM
Madellous's Avatar
Default true dual over the axle measurements/angles
does anyone have the measurements/angles for a 3 " over the driver side axle piece? i just need the piece that goes over the axle, unless someone has measurements and angles for an entire TD x pipe setup.. can i just mirror the pass. side over the axle piece?
Old 07-23-2010, 07:08 PM
01boydws6's Avatar
your not going to be able to mirror the pass side becuase of the panhard bar. I was going to go dual over but with my lowering springs its going to be real tight
Old 07-23-2010, 07:20 PM
omarrakeen's Avatar
ive tried to get any info abt this too but honestly i ended up with none. why wont use the stock over axle and get its mesurments? wont that work?
Old 07-24-2010, 07:46 PM
Madellous's Avatar
because i was going to try and go over the axle on each side for appearance, but i had the idea of copying the passenger side as a fail safe. if no one has any other solutions then i guess im going with the latter. thanks everyone
Old 07-24-2010, 08:05 PM
01badbird's Avatar
what about this to move panhard bar http://www.jegs.com/webapp/wcs/store...rm=142-phr004h
