Ls/6 intake Vs Edelbrock victor jr intake and elbow.
Old 07-25-2010, 05:54 AM
2l8iwon's Avatar
Default Ls/6 intake Vs Edelbrock victor jr intake and elbow.
Can anyone help or tell me how much more of a horsepower advantage i would gain Going from the Ls/6 intake to the Victor set-up??? any advise will help....
Old 07-25-2010, 02:01 PM
OUTLWZ's Avatar
I can't give you any numbers, but I have the LS6 intake and a buddy of mine has the victor intake with a nitro dave elbow.
I hit my power-band at a lower rpm range than him. Ofcourse he's also running the Trex cam. I can say that it mean as hell under his hood.
Old 07-25-2010, 02:07 PM
Old School Heavy
speedtigger's Avatar
The only direct comparison I have seen is in the book "Dyno Proven LS1 Thru LS7 Performance" by Holdener. However, in those tests, they had a carb on the Victor Junior. In his tests, The factory LS2 intake had a slight torque advantage up to 5,000 RPM where they were equal for the rest of the RPM range.
Old 07-25-2010, 11:32 PM
2l8iwon's Avatar
All good info... i'm just looking to find out what i can about this victor jr set-up.... anyone else have any horsepower comparison's??? Without a carb set up.... FI vs FI.... thx for everyone's help up to now....
Old 07-25-2010, 11:58 PM
LilJayV10's Avatar
Well there are about 50 different things that will effect it.
Old 07-26-2010, 01:10 AM
2l8iwon's Avatar
well not really... I'm just looking for people that have just removed the Ls/1 Or Ls/6 intakes and have just put the victor jr and fuel rails and elbow on an stock Ls set up... no motor work done!!! just stock and a set of long tubes... that should narrow things down some...... thanks for everyone's help up to this point....
Old 07-26-2010, 01:15 AM
LilJayV10's Avatar
That what I meant. If it was a bone stock setup or H/C/I/E car.
Old 07-26-2010, 01:22 AM
2l8iwon's Avatar
Ok fair enough...sorry bout that... i made it a little clearer...
Old 07-26-2010, 08:45 PM
2l8iwon's Avatar
nobody has this set-up with just long tubes and exhaust done????
Old 07-27-2010, 12:23 AM
LilJayV10's Avatar
Probably not. I guess most people wouldn't go with the Victor jr until major mods or boost.
You should search to see how much a LSx intake flows compared to a Victor x.
On a stock application it may not be worth it.
Just like any engine you can over, intake, exhaust, carb, etc it.
Old 07-27-2010, 10:23 AM
2l8iwon's Avatar
yes.. very true... i was just hoping someone did this set-up and i could get a baseline from them...
Old 07-27-2010, 11:39 AM
99_Z_155's Avatar
I looked into the vic jr too. From what ive been reading these things dont do you much good unless you are boosted. the runners are big and long, and you have to have that huge *** elbow on them. so im guessing the runners get lazy unless you have large cubes or you have boost.
Old 07-27-2010, 11:49 AM
Old School Heavy
Actually, the Victor Jr.s ports are quite short compared to the factory LS1 intakes. Have a gander:
http://www.edelbrock.com/automotive_...ctor-ls1.shtml
Old 07-27-2010, 12:00 PM
JCS20001's Avatar
Question i got a question
hay I'm tryin to do a engine swap in my 1999 camaro can a LS6 bolt into a camaro body or am i going to have to modify the fire wall
Old 07-27-2010, 04:14 PM
99_Z_155's Avatar
Yes i understand that, however they arent all that comparable because the LS intake is in a curved architecture, where as the vic jr is the old school shape. i still think those runners have lazy flow if you dont have the boost or cubes to pull more air.
Old 08-25-2010, 08:58 AM
2l8iwon's Avatar
well it looks likw i will just stay with my Ls6 intake for now...until i boost it... thanks for all of the info guy's,,,
Quick Reply: Ls/6 intake Vs Edelbrock victor jr intake and elbow.
